-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   P2 to FCP then from FCP back to miniDV Tape (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/76976-p2-fcp-then-fcp-back-minidv-tape.html)
Darrin Altman October 6th, 2006 01:16 PM
Is this as easy as selecting Print to Tape from FCP with my HVX200 connected to my Mac via firewire?
My present project was actually shot with a different camera but I have it in FCP as a Uncompressed 8 bit NTSC Sequence and I need to provide to client on miniDV tape. Will the above scenario work or is there more to it?
Thanks for your help.
Darrin
Barry Green October 6th, 2006 05:51 PM
Yes that'll work fine. Just be sure to set the "P2/TAPE" switch to "tape" on the back of the camera and the HVX will then operate just like any DV camera; FCP can take control and output right to it.
Darrin Altman October 6th, 2006 07:23 PM
Thanks Barry!
Shane Ross October 6th, 2006 08:14 PM
Uhm...the HVX-200 records to miniDV...which is the DV format. Uncompressed 8-bit will not record to DV tape. You need to drop your footage into a DV timeline and render...THEN export to tape.
Barry Green October 6th, 2006 09:53 PM
Well, yeah, I figured Darrin knew that, but you're probably right to bring it up.
The output through the firewire will be DV, and recorded on the HVX as DV.
Darrin Altman October 6th, 2006 10:41 PM
Glad you mentioned that because I honestly thought the transfer would convert the format.
