50i -? is it progressive?
in 1080 50i is camera recording progressive frames and uses interlaced mode for just transfering data or is it only interlaced scanning if I want 1080 lines?
because I see that in spec it says it can record 720p or 1080i so what does that mean? 1080i is not a progressive scan? |
in 1080 mode, the camera records 25p (progressive frames) within the interlaced stream.. much like the way DVX100 does progressive scan.. or teh HVX does non "PN" progressive..
with PAL what u get is a 2:2 pulldown NOT frame doubling (apparently.. but the 2:2 suggests otherwise..), but first frame priority, however i HAVE found that slowmo with this technique to be ultra ULTRA smoth and sharp so it wouldnt surprise me if the second frame is actually carrying workable data... ITs either that or i cant explain why progressive scan using this progressive technique can be so smooth for slowmotion... If someone can explain it, id love to hear it.. |
But whereas with 1080p/25 the lines would then be read out sequentially, with psf they are sent 1,3,5,7....etc for a field, then 2,4,6,8....etc for the next field, just as with interlace. Currently in the UK sport is broadcast 1080i/25 (to give 50Hz motion), whereas such as drama is produced and broadcast 1080psf/25. There the 25Hz motion is positively desired as "film-look". |
thanks :*) I understand.
| All times are GMT -6. The time now is 03:08 PM. |
