synchro scan problems
The other day, I tried to use the synchro scan mode to get a clear picture of computer monitors (set to around 85 Hz, as I recall...) Nothing I did to the shutter speed in synchro mode seemed to make any difference... same picture, no matter what. I finally ended up having to reset the monitors to 60 Hz on the computer itself. Needless to say, this is a worry, since I do a LOT of corporate work. Has anyone else run into this and, if so, is there some step in the process (that isn't immediately apparent) that you think I'm missing?
Describe your settings and how you set the synchro scan in more detail.
That would be helpful. Did you see the shutter speed come up in the screen display? |
You might not have had the shutter speed set to the actual synchro scan system.
Use the "shutter" and "speed sel" buttons to make sure that the camera's shutter speed is set into syncro scan mode. Then the changes you make will be immediately visible. |
I was definitely seeing shutter angles changing on the OSD as I made adjustments, but no effect on the picture on the flip-out. Was in the factory default F1 scene file, shooting DVCPro50. I see now that, even though the shutter speed next to Synchro Scan (1/48) was in blue (which usually indicates a parameter that can't be changed, I thought), that you can actually adjust it. I guess in this case, since the values change from blue to white once you hit 1/60th, that blue means "this is a value that isn't compatible with your frame rate." If that's in the manual somewhere, I missed it. I don't have a CRT here to check it, but I'm assuming I'll be able to get it to work next time. Thanks for the heads-up on needing to depress the shutter button AS WELL AS setting the synchro shutter speed in the menu. I'd tried that before, but you can't get to a synchro shutter speed with the buttons until you've already gotten the values out of the blue range. |
That's correct, if it's blue it's not possible to use it. You can't use a syncro-scan shutter slower than your frame rate, so when shooting 60i/60p, 1/60 is the slowest you can go; 1/59 would be blue and disabled.
You can definitely use syncro-scan in either film cam or video cam mode, and no they don't behave exactly the same. In film cam mode the shutter is expressed in terms of degrees, and tracks with the frame rate (so 180 degrees gives you 1/48th exposure at 24fps, but 1/120th exposure at 60fps); whereas in video cam mode the shutter is expressed in fractionals like 1/63.2, and that is a fixed exposure regardless of what frame rate you're running at. |
| All times are GMT -6. The time now is 07:11 AM. |
