-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Firestore Import into FCP (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/68789-firestore-import-into-fcp.html)
Craig Milne June 3rd, 2006 11:47 AM
I am shooting on the FS100 and I have shot some footage before I have recieved my MAC. I basically coppied the files to and external hard drive to access them when I needed them. I organized P2 but I did not copy the lastclip.txt file with my first 2 shoots. Is this footage lost foreever or can I recreate this file and trick the computer.
Thank God it is not the most important footage!
C
Robert Lane June 4th, 2006 11:17 PM
Craig,
If you've deleted those files from the Firestore then yes, those clips are rendered useless. That .txt file has code needed for the entire MXF data chain to be complete and readable/usable. I'm not sure the exact data that is listed in the file, but from Barry Wan Kenobi could most likely tell you.
Craig Milne June 5th, 2006 09:18 PM
Thanks Robert for the reply
Even though it is bad news!
I now copy all the files except the empty logs to my hard drive. The good news is that I can use raymaker or that other program to save the footage. I looked at the lastclip file from firestore and it seems easy enough, I will have to wai to see if it works.
Does anyone know if they can replicate the file?
Crag
