Greenscreen example
I have to say that I am very dissappointed in the actual resolution of this camera. The blocking from undersampling is easily noticable, and there is just a general lack of detail. That said, it keys relatively well considering.
I thought it looked soft too.
It's hard to know, since we don't know the settings selected. Well, we'll know a lot more once the rez comparison test comes soon. Steve |
Look around. Rez charts have been shot, and the results are not encouraging. They confirm what we've been seeing in test shots ... the "true" resolving power of the camera (CCD, lens, et. all) is pretty poor ... almost half what 1080 is capabable of.
Maybe one of you (or someone else) could post a reference to a greenscreen example so we can compare how the HVX200 still compares to how it "should" look. I'd like to see a nice example of " 'true' resolving power," an image that does not look "too soft," and one that you feel does not exhibit:
Thanks. |
Well, I must say this is much easier than DV. Big Time.
http://www.holyzoo.com/content/hvx20...s_Keylight.mov And that's not delving deeper in Keylight at all. With DV, I had to Color Smooth in FCP, export Uncompressed, tweak for a long time in Keylight, then do more custom matte work with Tinderbox. Anyone still majorly disappointed? Sure, maybe if you're used to HDCAM, uncompressed capture or film scans. ;) |
It does key cleanly ... that isn't my problem. The problem is with the lack of real detail in the shot, and the obvious color sub-sampling (especially around the edges) that seems to be exacerbated by the interpolation of the real resolution to the recorded resolution.
I see what you're disappointed by, but is it going to hinder your ability to create what you want to create? -steev |
If someone gave me the camera ... I wouldn't complain! ;-)
But since it's my $10,000 that I have to spend, if what I wanted was a camera in that price range for studio work, well the Canon XL H1 via the SDI outputs is the clear winner. The CCD has appreciably more real resolution and going out via SDI eliminates compression artifacts. |
Well, Joseph - right there is the nut.
Studio - no choice. But for other situations ? ... think this is where the HVX will make a lot of sales. |
Rob,
We are discussing keying, which doesn't seem to be done in the field too much! ;-) Derek, I assume that you don't want a real answer and are just trying to make a point? (It's very easy to compute how much storage you need.) Regardless, capturing to a codec like Cineform (or using Apple's AIC after the fact) are very viable solutions for even low budget NLE's. |
Can you just let me know a price range of what would need to be spent to do so? It sounds like you've done your homework on the subject. Even a low price range would be fine, as I'm not making documentary's or anything like that. Or, if there's a recent link within this forum that might be a good reference on the subject, no need to re-explain it if it's already been covered elsewhere. That's one of the great things about this forum - the huge archive of information it stores. Thank you Joseph. |
Sorry, Derek, I thought you were being facetious. My apologies.
it is true that an "end-to-end" uncompressed workflow is going to be fairly expensive. (Check out http://www.hdforindies.com for good info.) The reality is that the bulk of the average project doesn't need to be handled this way, though. In my experience you can use a very high quality an "intermediate" codec for the bulk of your work. My day-to-day is on the Mac. I know that I can do simple (mostly just cuts) edits on even a PowerBook. My main machine is a dual G5, and it performs well under almost any condition. On the Windows side, many people are very happy with the performance of Cineform based systems. Either way, you should be able to get into either for under $5k, and then add storage as needed. I know that in theory the HVX should have the advantage with the DVCPROHD codec, but real world images are revealing that the imaging chain (lens, ccd, processing) isn't using a fraction of that potential. My guess is you could pull a better key from the XL H1 even using HDV recording. |
