-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   HVX-200 Resolution at 1080p (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/57672-hvx-200-resolution-1080p.html)
Petr Marusek January 6th, 2006 11:22 PM
Panasonic HVX-200 from Kaku's test http://home.arcor.de/martin.doppelba...rts/0088YP.png
Result: 625Hx600V progressive
I compensated for some factors, like for instance a chart not filling the screen properly.
The Panasonic appears to have CCD's that employ both vertical and horizontal pixel shift.
Martin provided a total of 4 frame grabs from the Kaku's tests. I derived the numbers by checking all 4 charts.
Graeme Nattress January 8th, 2006 06:54 PM
Petr, link is broken.
Graeme
Petr Marusek January 8th, 2006 07:01 PM
Sorry, the guy must have disabled it. It is from Kaku's clips. Everyone has seen in it 600Hx600V; I saw 625Hx600V. The Kaku's clips, with various sharpness settings, should be available somewhere.
John Benton January 9th, 2006 10:38 AM
I think I'm getting ill
Mathieu Ghekiere January 9th, 2006 11:37 AM
What do you mean?
Not sure if I'm understanding the meaning of you post correctly :-)
John Benton January 9th, 2006 11:45 AM
Correct me if I am wrong, but isn't this not great res for 1080
maybe I amm not understanding Pixel shift correctly -
and just have to see it, but if it is only recording 600,
what ever you do to is isn't gonna be that great..
Does this even fall into the realm of Real HD
I don't mean to be inflamatory, I am just curious,
J
Mathieu Ghekiere January 9th, 2006 11:51 AM
Yeah, I thought you meant that with your post, but just a pretty weird way of letting it now :-)
Just wanted to know for sure I was understanding it right.
But if it is correct, indeed it's a pretty big dissapointment for many people I think.
Steven Thomas January 9th, 2006 12:03 PM
Which brings ups the question:
What's the minimum rez to benefit from HD 720 and 1080?
Martin Doppelbauer January 9th, 2006 01:03 PM
I don't know what happened to the link but this adress should do the trick and give you access to all the charts:
http://home.arcor.de/martin.doppelbauer/ResCharts/
For comparison I've also added some deinterlaced footage from the FX1 of a small toy train in various resolutions.
Michael Pappas January 9th, 2006 02:09 PM
Hi Martin, thanks for the tests.
One problem, which one is which. You didn't title which mode etc...
Here are some of your files. You need to indentfy on them your site..
0088YP.png 06-Jan-2006 14:40 1.8M
0089NO.png 06-Jan-2006 14:41 1.8M
0090H6.png 06-Jan-2006 14:42 1.6M
0091WY.png 06-Jan-2006 14:42 1.4M
XLH1 and HVX200 frame grabs and news here:
http://www.pbase.com/Arrfilms
Michael Pappas
Arrfilms@hotmail.com
PappasArts & Arrfilms Main site
http://www.PappasArts.com
http://www.Myspace.com/
Martin Doppelbauer January 9th, 2006 02:25 PM
I would, if I could.
These are not my files. These are frame grabs I made of footage that was shot by Kaku Ito in Japan. See this thread http://www.dvinfo.net/conf/showthread.php?t=57572
Sorry, I have no further information.
Michael Pappas January 9th, 2006 02:32 PM
Isn't that your directory Martin?
If so, Why can't you change the file titles? Since you made the frame grabs of Kaku's clips, I assume you uploaded them which gives you control of the file names.
The reason is, how can anyone know what there looking at you have directed them too. One shot could be no sharpness and the very next one could be Normal. However how would anyone know when the label doesn't tell them.
We need to try to keep things as clear as possible around here, since it does a disservice to all the tests that are being conducted, and add's frustration to new people coming here to see what's up with these new HD cameras and they can't tell what images there looking at. Your labels don't even say what camera. The way links are passed around these days they can end up anywhere...
For example. You can title them like this: HVX200/0-dtl/1080p24 or HVX200/-5 dtl/1080p24
In this case it tells the viewer that it's a HVX200 at 0 detail at 1080p at 24 fps. Or the second one it says all the same but now a -5 detail.
Michael Pappas
Matthew Greene January 9th, 2006 07:35 PM
Yeah, I can't help being distracted by the edge enhancement on the charts. It seems a bit too thick.
Martin Doppelbauer January 10th, 2006 12:20 PM
Michael,
I have received five video files of res charts shot by Kaku Ito in different camera modes (in total over 700 MB). I've made one frame grab of each of the five videos and gave them exactly the same filenames as the videos had. At the time I did this a few days ago there was no further information available which camera setups Kaku used for the five shots.
I have now looked again at Kaku's Homepage but still all he says is "More details to be written later". As soon as I know more, I'll update the filenames to reflect the camera setup used.
