Almost!
Get this? Or wait for 1080/24p?
Oh the dilemma! |
from what ive read this camera will do 1080/24p...so you wont have to wait...
Yes, it does 1080 24p, supposedly the full 1920 X 1080 instead of 1440 X 1080. Sweet, huh? Accomplishes it with 2:3:3:2 pulldown like the dvx-100.
Man, this camera is . . . sweeeeeeeeeeeeeeeeet. |
DVCproHD resolution is either 960*720p or 1280*1080p or 1280*1080i Rumour is that the CCDs will be 1280*720 and will upscale to 1280*1080 and downscale to 960*720. This fits with what I was told at the London Videoforum. I asked about the native resolution of the 1080i AJ-HDX400 camera and was told it was 1280*720, which I assume is 50p/60p at the CCD then converted to 1080i 50i/60i when recorded to tape. [edit: OK so the following is wrong, see later posts] Since the HVX100 does NOT record to tape, I assume that it saves discrete frames in 24p mode. Without tape, there is no need for the sort of methods the DVX or the Variam use to create 24p. |
Damn, I can't find the reference, but I read somewhere that the 1080/24p will be recording as 60i, using 2:3:3:2 (I think) pulldown, just like the DVX.
In 720/24p, I think it records only the frames required, so yes you'll be using something like 40Mbps bandwidth. Aaron EDIT: Found reference here |
Thanks Aaron, and the direct link to the specific post is here
Whoops, well, interesting, since it comes from Jan Crittenden that's pretty definitive. |
Sweet! I Thought I read it was only 720p. Awesome!!!
Wrap it up and put a bow on it. I don't even need to see it. |
| All times are GMT -6. The time now is 02:07 PM. |
