-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Does the HPX300 have Image Rotation for Cine Lens adapters? (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/235017-does-hpx300-have-image-rotation-cine-lens-adapters.html)
Tim Dashwood May 9th, 2009 07:21 PM
Does any one know if the HPX300 has electronic image rotation or "flip" for use with Cine Lens Adapters like JVC's 1/3" HZ-CA13U?
Giuseppe Pugliese May 9th, 2009 10:02 PM
Yes, it does. In fact it not only rotates the image in the VF and LCD, but also records the image upright onto P2 as well, eliminating the need for flipped modules when using a 35mm or 16mm DOF adapter.
Tim Dashwood May 9th, 2009 10:08 PM
Awesome. Thanks. I couldn't find that info in the brochure.
Giuseppe Pugliese May 9th, 2009 10:51 PM
No problem, in the manual its referred to as (reverse scan) I believe, so its a bit of a "secret power" the camera has. Its not really noted on the brochures but it does do it.
