-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Quick Question: Audio From Mixer (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/121029-quick-question-audio-mixer.html)
Pietro Jona May 6th, 2008 09:43 AM
hi all
i never worked with a panny 200 before and i've just been called for a job scheduled tomorrow. i'll do sound.
i'm going to use a SD 302 mixer and i wonder how to set the levels on camera. how do you find the -20 db level? is it like on the dvx100? first red brick is -12? how many db per brick? does the camera like levels running at the beginning of the red bricks like the 100?
thanks
pietro
Dan Keaton May 6th, 2008 03:32 PM
Pietro,
I recommend that you download the HVX-200 manual from the Panasonic website.
There are two vertical bars in the viewfinder (in the audio levels area).
I believe that the first bar (from the left) is -20db and the second is -12db.
I do not have access to the manual right now, but I believe the above is correct.
I welcome any corrections to the above information.
Barry Green May 7th, 2008 03:00 PM
The HVX200's meters are different from the DVX100's. There's set marks for -20 and -12, and there's no red at all except for when clipping.
TingSern Wong May 10th, 2008 10:50 AM
And there are no marks for 0dB either.
