SDI cable question Pana Related
I do have a Pana HPX500 & HVX200
To go from HPX500 to monitor within a few feet is there any difference if I use a component cable with BNC adapters from the SDI out on camera to SDI in on Pana monitor compared to buying a cable specifically for that ( Canare BNC to BNC (SDI) Serial Digital Interface Cable - 6 ft)? Thanks for your time. Darrin |
Guitar Center sells a Monster word clock cable - my research tells me that will work also - am I right??
[QUOTE=Darrin Altman;792638]I do have a Pana HPX500 & HVX200
To go from HPX500 to monitor within a few feet is there any difference if I use a component cable with BNC adapters from the SDI out on camera to SDI in on Pana monitor . Darrin I have a SPX 800 is similar camera to your HPX500, I use SDI out alot it works great, has embedded audio all with-in one BNC cable, component is good if your equipment is limited to component in/outs, I'd suggest go with SDI, cable length is no problem. Cheer Tom K |
[QUOTE=Tom Klein;792774]
HD-SDI is digital (as you are probably aware) so a cable either works or it doesn't.
For HD-SDI, you should get a 75 ohm cable with BNC connectors. If you actually study the spec's, it is difficult to find an actual cable that meets the specs. However, for short distances, sub-spec, true 75 ohm, good quality BNC Cables work. The following is a 3' true 75 ohm cable with true 75 ohm BNC connectors from Comprehensive. http://www.bhphotovideo.com/c/produc...le_to_BNC.html The following is a 1.5' version: http://www.bhphotovideo.com/c/produc...le_to_BNC.html I am currently using a 25' Comprehensive cable for HD-SDI successfully. |
