HVX Panasonic 60p and Music videos
Anyone know how much I need to speed up a song for a music video, if I shoot in 60p but played back for edit in 24p? the final product would be 24p.
I am using Final Cut Pro to speed the song up. I assume that it will have to be a percentage. If someone has done this or would know how to accomplish this. The look I want is the slow motion effect in music videos. Where the person is singing in normal speed but he looks like he is in slow motion. I figured I could do that with the HVX-200 at 60p and played back to 24p. But when I shoot it in 60p, I would need to play the song more than 2x faster... Any ideas? Has anyone already done this with the HVX. thanks!! |
The problem with giving exact answers is that the frame rates aren't exact, so even if someone comes in with the magic formula it'll still have to be tested to be sure.
But, with that said, the basic formula is that you first want to determine your footage playback speed, and once you know that, it tells you how to modify the song. So (in theory) if you're wanting to shoot 48fps slow motion for a 24fps timeline, you'd be getting 2:1 slow motion, so you'd have to speed up the song so that it plays for exactly half as much time as normal. So again, in theory, you'd take a four-minute song and speed it up so that it plays for exactly two minutes. Then you'd set the HVX into 24pN mode, set your frame rate to 48, and play the sped-up song and have your actor/singer lip-sync to the super-fast version of the song. Then when you play your footage back it'll be in 2:1 slow motion, and you'd marry that version of the footage to your original song, and they should now be in perfect sync. But they won't be. Because there's theory, and there's this troubling thing called "reality," and the reality here is that the frame rates are not what they say they are. 24fps is not, for example, 24fps; it's 23.976. And 48fps is not 48, nor is it 47.952 (as you might think, if it's twice as fast as 23.976)! It isn't. It's actually 48.17. And 12fps isn't 11.988, it's 12.26. Except if you're on the PAL HVX, where it actually is 12.500, half of 25.000. So you need to adapt the formula to comply to the actual frame rates. Fortunately the HVX does part of that work for you, by doing the 24pN (or 25pN) conversion in-camera, so we only have to concern ourselves with how much to speed up the song by. I haven't tested these, but I'd guess they're accurate; if anyone tests them and finds them inaccurate please let us know. For an NTSC/US HVX, using a 24p timebase, for the following frame rates, adjust the song speed to: 12 fps: make song last 1.956x longer by stretching it to 51.1% speed 18 fps: make song last 1.333x longer by stretching it to 75.0% speed 20 fps: make song last 1.226x longer by stretching it to 81.6% speed 22 fps: make song last 1.067x longer by stretching it to 93.7% speed 26 fps: make song last 0.907x as long as normal; play it at 110.25% speed 30 fps: make song last 0.800x as long as normal; play it at 125% speed 32 fps: make song last 0.747x as long as normal; play it at 133.87% speed 36 fps: make song last 0.672x as long as normal; play it at 148.81% speed 48 fps: make song last 0.498x as long as normal; play it at 200.80% speed 60 fps: make song last 0.400x as long as normal; play it at 250.00% speed For an NTSC/US HVX, using a 30p timebase, for the following frame rates, adjust the song speed to: 12 fps: make song last 2.445x longer by stretching it to 40.91% speed 18 fps: make song last 1.667x longer by stretching it to 60.00% speed 20 fps: make song last 1.533x longer by stretching it to 65.23% speed 22 fps: make song last 1.333x longer by stretching it to 75.01% speed 24 fps: make song last 1.250x as long as normal; play it at 80.00% speed 26 fps: make song last 1.134x as long as normal; play it at 88.22% speed 32 fps: make song last 0.933x as long as normal; play it at 107.14% speed 36 fps: make song last 0.840x as long as normal; play it at 119.05% speed 48 fps: make song last 0.622x as long as normal; play it at 160.73% speed 60 fps: make song last 0.500x as long as normal; play it at 200.00% speed For the Euro/PAL camera it's different; the timebase of PAL footage is 25.000 fps, so that makes it easier. But the other frame rates may vary, so it needs some calculation too. For the PAL/EU/AUS/NZ cam, set the recording mode to 720/25pN, then set your frame rate to whichever your chosen fps is. Then adjust the speed of the song according to this table: 12 fps: make song last 2.000x as long as normal; play it at 50.00% speed 18 fps: make song last 1.400x as long as normal; play it at 71.44% speed 20 fps: make song last 1.266x as long as normal; play it at 78.96% speed 23 fps: make song last 1.080x as long as normal; play it at 92.60% speed 27 fps: make song last 0.920x as long as normal; play it at 108.68% speed 30 fps: make song last 0.840x as long as normal; play it at 119.04% speed 32 fps: make song last 0.778x as long as normal; play it at 128.56% speed 37 fps: make song last 0.680x as long as normal; play it at 147.04% speed 48 fps: make song last 0.520x as long as normal; play it at 192.32% speed 50 fps: make song last 0.500x as long as normal; play it at 200.00% speed |
Thanks Barry,
WOW! This gives me a great place to start and answers a lot of questions. I will give these a shot and post back here with my results. Thanks for the quick response. |
Barry,
That's a great chart. Thanks! |
Barry is being too smart. I do this all the time. I make the song 250% and PITCH ADJUST. Shoot 60P, recorded to 24PN, drop it in a 24P timeline.... voila. There will be some ebb and flow on sync but it will likely be due to performance issues so MAKE SURE YOU PLAY BACK ON SET! Also, make sure the artist gets the song in advance and can practice. Here is an example of this in a video I did last year.
http://mh.tilted.com/bio/go_final.mov ash =o) |
Thanks for the clip, really nice work.
| All times are GMT -6. The time now is 02:27 AM. |
