GH6: AF doesn't work. help! URGENT!
Hi, I'm in Indonesia to make a documentary. Sometimes I need to use AF. I've always used it. But my GH6 here in Indonesia doesn't work. I don't know if by mistake I touched something in the MENU that I shouldn't have touched. But, I do not think so. I have the Leica 12-60mm. On the lens the button is moved forward to AF. Can anyone tell me why the AF no longer works? THANK YOU
Re: GH6: AF doesn't work. help! URGENT!
Hi, Adriano.............
First, how long have you been in Indonesia and are/ have you been staying in an air conditioned room(s)? If the answer to the latter question is yes, has your camera gear been going in and out of that room(s) with you all the time of your stay? If the answer to that question is "Yes", what precautions have you taken to keep your camera internals dry, if any? I'm just trying to eliminate the most likely culprit if this isn't a case of simple finger trouble/ brain fade. Regards, CS |
Yes Noa, same position but called MF, C , S. Needs to be in C for continuous autofocus. You can also set range in the menu to restrict the autofocus to a range. Like you I never use autofocus. Single touch autofocus will work in MF either by pressing the AF button or touching the AF soft button on the LCD.
Thanks for your precious info. You are right. The sun cooked my brain. ;) ;) Now I fixed it. The lever behind the camera moved involuntarily. Thanks again.
Glad it was that simple for you to fix. Have a good time.
