Re: Report of the trip in Ethiopia with the GH5
Could you tell me why do I have to buy a video camera? Do you not think I can become more expert om GH5?
Or like in your case using autofocus that is causing missed focus, that is a limitation of the gh5 and in such a case you manually focus or close down your aperture for a deeper dof. The conditions you shoot in, that you think we don't understand, has nothing to do with the problems you have. I shoot weddings and I"m sure they can be somewhat equally challenging to cover, everything happens fast, no second takes, difficult to get good audio, difficult light conditions etc...and I use a GH5. My colors, exposure and sound is fine. That doesn't mean I don't make mistakes, I do, most of the time it's my fault and sometimes it's a limitation of the camera that I know of and accept that this can happen, that's why I use more then one camera or use b-roll to cover up my mistakes as good as I can. |
There are firmware updates for the GH5 and GH5s which are supposed to improve the autofocus. Just thought I'd mention it in case it helps.
Why the -2 contrast, and what WB preset? Why are you using 400 ISO and an ND filter? Why are you using Photo Style 'Natural'? What resolution are you shooting? What lens did you use for the samples you provided? When you post to Dropbox your original source, and the Edius render, it doesn't show what is needed as a comparison, as Dropbox will process and what you have posted is in 720p. |
8 bit because I need to shoot in 50p. Why 400 ISO and an ND filter???? It is because this couple worked fine in my country. Why? If you use 100 ISA would you not use the VNF???? Natural is the one of the most flat preset and with I made it even flatter WB preset because some times I have no free time to make the WB and because in my country WB preset works fine but not in Africa Resolution: UHD, 50p Lens: Leica 12-60 mm |
I don't like to use that Variable ND filter in my next trip in Africa. I'd like to buy a new fixed ND filter but a good filter. I don't like dominant color, vignetting and above all I don't not like if the filter lowers the definition. I need a 62mm ND filter but I don't know about how many stops I need if I shoot in Africa. Do you think 6 stops are good?
If you know a really good ND filter could you write the precise model please? |
