GH4 Doesn't Auto-Focus Worth #$@!
Picked up a GH4 and the Oly 60mm macro lens. Set it to 4K at 30 fps, then tried 24 fps, then 1080. Set it as AF/AE Lock is set to AELOCK, AF/AE LOCK set to off, shutter AF on, and QUICK AF on.
Tried both AFS/AFF and AFC switch settings. The camera doesn't autofocus worth @#$!. It's running body firmware v 1.1, and the lens firmware 1.0 with the latest body firmware on its way. When I slow pan on macro, it sometimes autofocuses after awhile, other times it WAY overshoots the focus to a blurry mess, other times it overshoots, then undershoots and generally hunts all over the place rendering it useless. Now I know nobody is complaining much using wide lenses and autofocus, but I am still trying to figure out of the camera is junk when it comes to macro autofocus, or is the operator junk? Panasonic support line is a joke. They advise you that calls are monitored and recorded, then when I told them I do the same, they said I don't have their permission to which I laughed. I'll be sure to share that with the Panny guys at NAB. I am about ready to dump it all for the Sony A7RII if I can't get it to autofocus decent. |
Re: GH4 Doesn't Auto-Focus Worth #$@!
You can't expect a dslr with a macro lens to do 100% accurate autofocus while you are panning, either learn to operate your focus manually or buy a small sensor camera that has a much deeper dof. The GH4 is not "junk", it needs an operator with experience to get the most from it. There are a few camera's though that might work better for you, I believe the canon 70d has a very good autofocus system and I have seen some impressive autofocussing on the sony a6000 and eventhough they are better don't expect them to be failsafe. |
You're right, Noa. Calls do get monitored mostly to keep tabs on the employees, though it does help in the case of a really awful (violent) customer calling. I did work for Amazon.com and it happens.
The 70D is the king bee when it comes to autofocus, and focus tracking. You need to use STM lenses for the absolute best results, which aren't the best quality in the world, though I haven't gone really high end like L or Cine lenses. Maybe I'll rent some someday. I'd be curious to know if anyone uses auto focusing with macro work. Even on my 70D I don't use motion/panning when doing real macro work. I manually focus. |
Noa, the issue is they want to record conversations, and thus have no expectation of privacy, but they demand you not record the same recorded call. I realize some prefer to argue via straw arguments, but I save that form of entertainment for the political forums. I am here to rely upon people with far greater expertise than I on some new gear unfamiliar to me at this point.
As to macro, it's not possible in the environment I shoot in to use manual focus. The subject and conditions are too dynamic, the depth of field is too limited and I have middle aged eyes. With my old 3ccd HDV cam, I could zoom in with +3 or + 5 achromatic diopters on the fixed zoom lens till either autofocus went out of focus, then I pulled back a bit, or till the subject was framed and sized right. At those points, focus was rarely lost as the tiny subject moved about a bit. I am sure the GH4 and Oly 60mm macro works great on a tripod shooting stills when you have time to compose, and focus, and focus peaking works for stills, but it is my understanding focus peaking does not work in 4K video mode on the GH4. I hear the camera autofocuses well with the wide zooms, but macro is my thing. Unless I am off on my cam settings, perhaps either a zoom with image stabilization and with achromatic diopters might be better, but not as good as needed. That's why I wonder if the new Sony A7RII with advanced autofocus might be better suited for my digital video shooting style. |
If I am reading your description of your old HDV camera correctly, you were not using macro but zoom extenders. Macro is frequently enabled by changing the back-focus of lenses which AF has a hard time dealing with, of course depending the AF technique used by the camera and the subjects being photographed. Auto focus with zoom extenders can work better.
The reviews I have seen have noted that this particular lens is not the fastest macro AF lens around especially with subject movement. Personally I have not found any auto-focus lenses that were reliable at all with macro. Manual was the only way to go. The GH4 however, with the right lenses, has very fast auto-focus in most typical photography situations. Your photo needs are specialized and I hope you can find the right combination to continue to film the way you want. |
Thanks William and others. I was using a screw on achromatic diopters on the old HDV cam and it worked quite well. I never saw the need for a dedicated macro lens. With the same cam, I could screw on a wide angle adapter and that worked really well too. Now I am faced with buying dedicated fixed and zoom lenses.
With the Sony FS700 I only needed 4 lenses, an ultra-wide zoom, and low light beast, and a longer zoom, but that's all tripod work on more or less fixed larger subjects. For travel, the form factor of video cams just does not work as well as the new crop of dslr's that are now doing 4k/quadHD internal at less than half the size and weight. I just need to solve the macro focusing issue if that is even possible. I wonder if I go to a Panasonic zoom with an achromatic diopter added on the front if that would autofocus better for video than the dedicated macro lens. With the former, at least with the right zoom lens choice I would get image stabilization. |
Hey Dave,
For sure the focus peaking works, & works very well in 4K movie mode. As for keeping things in focus in video mode using AF, well i'm just not sure that the GH4 will be your friend in this situation. I would definitely try using manual focus with focus peaking, you may find it easier than you think to keep things in focus with it. |
I don't think peaking works in autofocus mode.
Why would you need focus peaking in automode? Focus peaking is a visual aid when you are focusing manually.
My testing with a 17mm Oly lens in 4k on a stabilizer is that the cam wants to back focus on the background even when the subject fills more than 2/3rds of the frame when it is moving with you. I have never found a way to make it want to stay up front on the subject.
After a number of tries, I have given up auto focus for anything. A half press of the shutter button locks focus extremely well, but then at some random point it always starts hunting around for the background. Manual focus is the only way to truly get the GH4 to stay put that I've found. If someone has a solution they can spell out of exact settings to get AF to lock with a half press then not change while recording I'd love to hear it. Cheers, Pete |
When i use a autofocus lens panasonic 12-35 f2.8 on the GH4 , it focuses auto on the C1 and C2 mode however on the C3 modes the autofocus stops of and i don't have any idea about why it does it.
The peaking allows me to do the focus fast however i would love the auto focus to work on the C3 modes, anyone else faces this issue. |
