-   Panasonic LUMIX S / G / GF / GH / GX Series (https://www.dvinfo.net/forum/panasonic-lumix-s-g-gf-gh-gx-series/)
-   -   GH4 problem with motion blur and stuttering vision (https://www.dvinfo.net/forum/panasonic-lumix-s-g-gf-gh-gx-series/528600-gh4-problem-motion-blur-stuttering-vision.html)
Craig Saunders June 1st, 2015 05:26 PM
Hi folks,
I need some advice.
I recently shot a courtroom on my GH4. I needed a long roll (90 minutes plus) so I used the Panasonic 64gb card and set the camera to:
FHD 50 MBS
1920 x 1080 - 25p
Shutter speed 1/50
This is the problem. At the start, using mostly available light, everything looks fine. When people move in the frame it looks normal. But then we turned on 2 x 1k lights and things got weird. The vision becomes quite stuttering and people blur when they walk through frame.
Heres the vision :
I'm a bit baffled. My initial thought is that 50 mbps may have been too low a rate to allow the camera to write all the info, but I have no scientific basis for believing that. Otherwise, I'm at a loss to know what I did wrong to get that result.
Any advice is much appreciated!
Craig
Pete Carney June 1st, 2015 07:35 PM
Re: GH4 problem with motion blur and stuttering vision
Are the two different clips in the same file? I almost looks like it's shooting 15 frames per second at a really slow shutter in the second part. I've never seen anything like that with LED panels and my GH4 at 1080-60p or 4K UHD 30p.
Cheers,
Pete
Gary Huff June 1st, 2015 08:37 PM
It looks like you accidentally adjusted the shutter when trying to adjust the iris to compensate for the new lighting.
Noa Put June 2nd, 2015 12:59 AM
If you look in the motion picture menu, what setting is the exposure mode set to?
