GH4 records for 90 minutes with Delkin 32GB 400X card
Just took a Delkin 32GB card and formatted it. I set the GH4 to 1080 59.94p 200 Mbps ALL-INTRA. It said 20 minutes 56 seconds remain on the card. The camera rolled for just over 90 minutes. I put the footage in premiere and it is all there. 90 minutes.
Delkin Devices DDSD400-32GB: SD400 UHS-I Secure Digital Memory Cards, Rated 400X - 65MB/s Read, 41MB/s Write, Class 10 Completely confused about what a U3 card is? Well. Scott Clark at Delkin Devices sent me this: https://www.sdcard.org/consumers/speed/ U3 is just UHS-1 30mb/sec minimum. Any questions? GH4 is in stock now and ready to ship! Panasonic DMC-GH4 |
Re: GH4 records for 90 minutes with Delkin 32GB 400X card
What was it you were recording for 90 minutes? Was there any motion or detail? 200mbps is 1.5Gb/minute, which should require over 130Gb to do 90 minutes. I'm assuming the camera is using VBR with 200mbs as an upper limit, in which case recording time is going to be affected by the level of detail and motion in your shots, and I wouldn't expect to see 90 minutes on 32gb cards in normal use.
Good point. I had the 42.mm F1.2 on it with an out of focus shot of some junk on a filing cabinet next to my desk. So my test for tomorrow is to put it in our showroom with an in focus shot and people occasionally walking through. Right?
You should handhold it and give it a lot of fine, moving detail. Long enough for the file to span on the card (about 4-5 minutes).
thats 30MB not 30Mb minimum stable write speed for a U3 card. Get that thing out of the air conditioned office and not pointed at a wall and you might see a diff.
If only I could figure out how to make the Kessler Cineslider go back and forth all day...
Ok. In focus shot with people walking through. Got it. It will be on a tripod. I could see the time adding up / counting down in the EVF the entire time. |
Ok. So this time I had a scene in focus with lots of contrast and detail and people walking through occasionally. Unfortunately when I hit RESET on the camera and built up the settings I had it on 1080 29.97 not 1080 59.94 as I had before. Sorry. It was set to ALL-INTRA 200 mbps again though. It recorded for 47 minutes 39 seconds. The lengths of the 8 clips recorded were 2:41, 6:24, 6:27, 6:24, 6:20, 6:26, 6:26 and 6:26. Enough on this one... time to hand it to someone with a helicopter to shoot some footage...
I moved the question to a better thread
You don't have to have it record for nearly that long. A couple of spanned clips is more than enough, because spanning is where the real bandwidth is needed.
| All times are GMT -6. The time now is 04:47 AM. |
