Confused about which types of lenses I can use for GH2/3
Have done some googleing around which types lenses I can use for the GH3 but cant find what types work (can only find lists of specific lenses). If there is a good article about his let me know, otherwise here are a fe questions.
1) Can I use all lenses which are referred to as 'micro four thirds',micro 4/3 or m4/3? Wlll all the features (aptitude, auto focus...) work for all lenses? 2) Will all autofocus Olympus fit lenses work fully (does autofocus work). 3) Will all autofocus Panasonic lenses work fully. 4) Canon EOS lenses can be used with an adapter but the camera can not control the aptitude so a adapter with aptitude blades must be used like 5) I guess Nikon fit and Canon EF lenses will work with the appropriate adapter? 6) What about Sony NEX lenses? Regards, Ben |
Re: Confused about which types of lenses I can use for GH2/3
All lenses on the following chart will work with the GH1-2-3.
This chart lists every single lens that can be used natively, or with the Panasonic adapter. Lenses that require the adapter are noted in a special section: Four Thirds Lens (Coupled with mount adapter DMW-MA1) (*11) Lenses such as Canon, Nikon, Pentax, Sony all require adapters. Different lenses require different adapters which are made by various manufactures. Compatibilities of DMC-GH2 | Compatibility | Digital Camera | Product Support | Support | Panasonic Global Some users would consider the Olympus Four Thirds lens below the single greatest lens available for the camera, along with the longer version. These two lenses cover most common focal lengths, from 12mm to 100mm between the two. If you wanted to save yourself a lot of time and grief, you could buy these two lenses and you would pretty much be done with lens shopping. For me personally, were I to own these two lenses, I would need nothing else. The lens listed below is exceedingly difficult to find used at a reasonable price, so if I were interested I would snatch it up immediately. http://www.dvinfo.net/forum/private-...3-adapter.html |
Thanks, computability was the word I was looking for.
Computability chart is useful, shame it only has model numbers for some lenses, would be nice to know focal length/f stops etc. (just spend some time on the Panasonic website looking for model number for 14-140 without luck, '14 140 lens' returned lots of lenses but not the one I was looking for. Regards, Ben |
Ben, its not complicated it just seems that way. Look on the Panasonic site for Lumix lenses, they all fit.
All 4/3 lenses and M4/3 lenses on the Olympus site will work, the 4/3 need the adapter. |
The model number for the 14-140mm is H-VS014140 The model number for the 14-4mm2 is H-VS014042 The model number for the 20mm is H-H020 The model number for the 14mm is H-H014 etc. If you use the model numbers, you should go right to the lens page. That said, here is the complete Panasonic lens lineup: Digital Interchangeable Lenses and Conversion Lenses | PRODUCTS | LUMIX | Digital Camera | Panasonic Global Cheers, Bill Hybrid Camera Revolution |
The two Olympus zooms that Jeff mentioned are AFAIK the only F/2 zoom lenses available for any brand of camera. Panasonic have recently come out with a 12-35mm F/2.8 & 35-100mm F/2.8 which are more affordable than the Olympus zooms & also have image stabilisation. |
I just replaced the 14-42mm "kit" lens that came with one of my GH2's with a slightly used 12-50mm Olympus Zuiko lens found in B&H's used dept. There is one other left there at $369:
http://www.bhphotovideo.com/c/product/800902195-USE/Olympus_v314040bu000_12_50mm_f_3_5_6_3_ED_M_Zuiko.html Outdoors in reasonable light this is all the lens I need as a "walkaround". It has a half life size macro mode, power zoom, and works on the GH2 like it was made for it. Being a full frame equivalent of 24-100mm it has a very useful range. Indoors or night city scenes I use a Lumix 20mm f1.7, and the Olympus 45mm f1.8. Makes for a very flexible outfit. I've also collected the Lumix 14mm f2.5 wide angle, the Panasonic Leica DG Summilux 25mm f1.4, and the Lumix 45-200mm zoom for when I need longer reach. All are Micro Four Thirds lenses and the Olympus m4/3rds lenses function on the GH2 like they were made for it. |
I discovered that a new lens is $399 at B&H until December 24 and if you need adobe lightroom or photoshop elements, the combined price is less than the used lens and software combined plus shipping is free: http://www.bhphotovideo.com/c/product/835398-REG/Olympus_V314040BU000_12_50mm_f_3_5_6_3_ED_M_Zuiko.html |
For $200 more you can have the Olympus 14-54 F/2.8-3.5, a much faster lens, FYI.
I did do it primarily for the extra wide angle and the added tele but also for the power zoom and half life size macro capability. It's a very useful general purpose lens and I'm happy with it. I also "nabbed" one of the used GH2 bodies they had. Price dropped from $539 to $399 on the 9+ condition sample they had. They also priced the one other 9 condition body at $399. I know the new bodies are now going for $499 but since I have a GH3 on pre-order, that $100 made a difference for me. It came in today and looks new, still had original firmware so I put Lpowell's Flowmotion 2.02 on it and all seems well. |
Thanks for all the replies, was looking at
I read somewhere the autofocus does not work during iideo on (at least some) of the sigma lenses. Is this true? Ben |
Ben check the compatability list, it will tell you which features will and will not work for each Sigma lens. If the Sigma lens is not on the list then it's not compatible.
The 19mm is not on the list at all. The zoom lens you mention is not the II series version so I would not bother with it. I've had the zoom in the series II version, it worked but I would strongly suggest the Olympus equivalent instead. It's a MUCH better lens and works much better with the camera. Why not a Panasonic 20mm F/1.7? It's a no brainer if you're looking for that focal length. If money is an issue I would save up, unless you just can't afford it. The 20mm is made for the camera and is an incredible value, IMO. |
Hang on, the 19mm 2.8 is on the list, well it seems to be.
I use a Rig and will be getting a Matt box so from my understanding a pancake lens is not a good idea. Ben |
| All times are GMT -6. The time now is 02:10 PM. |
