DMW-MA1 Adaptor ?
If i were to get this adaptor which wide angle zoom lens would be best that is no more expensive than the olympus 9-18mm micro four thirds lens, i use long lenses mostly but will need a wider zoom than the kit lens as well Compatibilities of DMC-GH2 | Compatibility | Digital Camera | Product Support | Support | Panasonic Global shows the available lenses i can not find a panasonic fit sigma 10-20mm in the uk.
Re: DMW-MA1 Adaptor ?
This adapter allows all four thirds to fit micro, but you are still very limited to find fast wide angle zooms - ie. F2.8. Most are F.4
You can get the Sigma 10-20 at B&H and this is a good lens. http://www.bhphotovideo.com/c/product/559263-REG/Sigma_201107_10_20mm_f_4_5_6_EX_DC.html |
Is that lens rated better than the olymous 9-18mm micro lens, thanks for the reply
| All times are GMT -6. The time now is 10:05 PM. |
