-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   My color bars are bleeding (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/91074-my-color-bars-bleeding.html)
Eric T. Johnson April 9th, 2007 11:12 AM
Hi, I'm calibrating my brand new JVC TM-H150CGU and when I generate color bars from the DVX they bleed slightly onto each other. I was able to calibrate the monitor properly despite this, but I was never able to stop the bleeding. The DVX was hooked up via S-Video.
Please help!
Oliver Fokin April 15th, 2007 03:41 AM
It's the DV compression that is causing the color bleeding. Push "color off" and you should see a the bars clear in B&W. I have a 17" JVC myself and get the same results so don't worry, you're monitor is fine :)
