-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Panasonic AG-MC100G XLR Microphone (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/6590-panasonic-ag-mc100g-xlr-microphone.html)
David Hughes February 3rd, 2003 10:43 PM
Hi - Am I right in saying that the Panasonic AG-MC100G XLR Microphone is the one feature in many of the promotional pictures of the camera (as can be seen in the following link:
http://www.panasonic.com/PBDS/subcat/Products/cams_ccorders/f_ag-dvx100.html )
Anyway I was wondering if this mic was available yet and if so how much it retailed for?
Many Thanks,
Dave
David Nussbaum February 4th, 2003 08:50 PM
forget that mic and go for the SGM x2
www.bhphotovideo.com
i just got it and its so amazing. I knew it would be good, but i was blown away. its only 220 at that site too, and 300 at others.
Steve Nunez February 5th, 2003 07:14 AM
If you add the SGM or other XLR mike can you still retain the use of the stock onboard mic? (as in using both the aftermarket mic and onboard at the same time- like recording 4 channels?)
Probably a silly question but just curious.
David Nussbaum February 5th, 2003 09:41 AM
i dont think so, since you need to switch to input 2 for a new mic.
I dont think it would be a good idea anyway though, since the mic it comes with is no better than a mic that comes with a 200 dollar Hi-8 cam X[
Skip Hunt February 5th, 2003 12:42 PM
Actually you can use the on-board mic and xlr at the same time. Just use the xlr on channel 1 and select "int" for internal mic for channel two. The mic isn't great, but completely useful for ambiant sound, especially when mixed with the xlr external mic on channel 1.
Skip Hunt
Zac Stein June 27th, 2003 11:48 PM
I can get this mic AG-MC100G for $100 USD in a package as with the dvx100, is it worth getting, i already have a k6/me66, was going to use it as my backup mic...
Should i just save the $100 ?
Zac
Dean Harrington June 29th, 2003 02:58 PM
mike....
save the $100 and get a good mike.
Dean Harrington June 29th, 2003 02:59 PM
sorry that was.....
mic - the other mike's not here. LOL
Yang Wen June 29th, 2003 03:04 PM
The SGM X2 is 16 inches long. There is no way you can mount that on the DVX100 and still have it be useful. How is the SGM X1 compared to it?
Dean Harrington June 30th, 2003 12:03 AM
He can....
put an extender on the mic arm and that should do it. got to get the mic out of the wide angle lense.
Yang Wen June 30th, 2003 05:55 AM
No I'm saying it will look stupid as hell having a mic that extends for the length of your camera, maybe even more!! Definitely draw attention to yourself and then when the other pros sees it's an Azden, its alll over...
Jarred Land June 30th, 2003 12:05 PM
try nrgresearch.com I bought the Schriber 568 from them and it is better than the Azden mics and is only about 12" long. Its only $139.00 special introductory price, you get all sorts of cables and connectors and mounts, a nice Hard aluminum case and soft bag. It is a little heavy (its all metal construction, not cheap plastic)
I think next month though the price goes up to $300, so better get it while you can. EVStape.com has it in stock, or at least they did when i got it.
Yang Wen June 30th, 2003 04:30 PM
Apparently the Schriber has a hiss problem. I wouldnt recommend it, also its rated freq response is rather narrow.
http://www.dvinfo.net/conf/showthread.php?s=&threadid=8842&perpage=15&highlight=Schriber%20568&pagenumber=5
Rob Taylor July 1st, 2003 06:36 PM
I tried the Schriber and noise a slight noise problem, glad someone else has reported that I thought I had a bad unit.
I have both the Azden SGM-1x and 2x. If you want to use the 2x on the DVX100, just slide it back farther in the shock mount or remove the barrel extension.
Rob
Jarred Land July 1st, 2003 10:12 PM
I have the 568 on MY DVX and there is no Hiss on either setting.
That thread you are pointing to is the 568 used on a GL2 with a non xlr connection locked down to the solid mount... two different worlds.
The cable that comes with the 568 is also terminated very poorly with no true ground-shielding seperation... i didnt expect a good cable with the price of the mic...
The 568 in the DVX's shockmount works great.. at least mine does. And the frequency response between the two are both in the same Audible region.
I would not take the advice from someone advising not to buy it that does not have one; just is yapping off of hear-say.
