-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Camera dosen't show up using firewire (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/31691-camera-dosent-show-up-using-firewire.html)
Barney Wood September 10th, 2004 10:16 AM
My camera isn't showing up on my laptop g4 powerbook. The beach ball spins,,,,, but as soon as I unplug the firewire everything goes back to working normal. When I open Final cut pro 4 - it says it doesn't see anything DV device. Is theier something wrong with my camera or is there something else I need to download for this camera?
Jeff Donald September 10th, 2004 11:51 AM
What OS are you using?
Barney Wood September 10th, 2004 12:52 PM
os 10 - I'm at work right now, but I think at home it's 10.2.1? Actually the camera has been making the computer hang for awhile until I unplug the firewire. Sometimes though, the computer does see it! I'm really stumped with this one! any advice would help!
Jeff Donald September 10th, 2004 03:23 PM
Upgrade to 10.2.8 using the combo update from the Apple support site. The upgrade is free, but fairly large at 97MB. I hope you have broadband.
Barney Wood September 10th, 2004 04:23 PM
Thank you so much! I'll give it a try! I have broadband at Work (I work for Comcast) But I live way out in the country and only have dial up. I'll burn a CD, bring it home and give it a try. I'll let you know what happens. Thanks again
Barney Wood September 11th, 2004 10:01 AM
Dang it!...It still doesn't work! I plugged a Hi8 dv cam in the firewire ports and the computer recognized it. But, unforetunately it doesn't see the ag-dvx100. I have a feeling that the firewire port on the ag-dvx100 is bad. What do you think?
Jeff Donald September 11th, 2004 12:27 PM
It is beginning to look that way, indeed. Did you repair permissions after updating the OS to 10.2.8?
