-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Dirt Inside Lens (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/125375-dirt-inside-lens.html)
Christopher Williams July 6th, 2008 12:36 AM
Dirt Inside Lens
I've got a DVC60 that has been serving me extremely well over the past few years but it's gotten a little too much junk blown at it while filming airshows. Its not on the outside of the lens because that gets cleaned after every couple shoots. The only thing I can think of is that somehow the dirt got inside the lens. Its been causing focus problems at wide angles, especially with cloudy skies. Is there a way to clean it out or does it need to go to the shop?
Thanks in advance,
Noah Kadner July 15th, 2008 05:15 AM
I suppose you could get lucky blowing compressed air through the body but it's not what I'd do. I'd send it in for service- they can clean up the heads while they're at it. It's not a bad investment on a camera that's served you for so long already.
Noah
