-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   Slow shutter set up (for Dan) (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/110571-slow-shutter-set-up-dan.html)
Peter Jefferson December 19th, 2007 03:28 AM
In progressive, you can select it through the shutter button without much fuss. The camera MUST be in progressive mode though. In interlaced, you have to allocate a custom button to be set as "slow shutter." You do this in the menu.
In cam mode, turn off the shutter altogether. Now press the custom shutter button you have just created. It will tell you its processing.
Once your screen comes back, you will have an option of several slower shutter speeds which you flip through by pressing the shutter button.
1/25th is one option which this question was specific about.
You should note that you can't use gain or auto focus when using this feature.
Dan Burnap December 23rd, 2007 08:00 AM
Thanks Peter!!!!!
