-   Panasonic DV / MX / GS series Assistant (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/)
-   -   Use DV852 just for voice overs (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/8928-use-dv852-just-voice-overs.html)
Bryan Roberts April 23rd, 2003 06:20 PM
Hey all. Well I have this project that is due in the next few weeks in a marketing class of mine and I decided to do a promo video. Budget has it right now that I can't afford the mic that I need/want and I'm trying to make due with what I have. The mic on my DV852 is by far the best one I have around here and I'm trying to find out a way to just record myself talking using my camcorder. I have programs such as Sound Forge, Premiere 6.5 and am running Xp. So far, I have run a coax cable from the audio vid in out switch to a stereo mini jack converter and then to my sound card as the microphone. When I have the camcorder set to video, the sound is mainly distortion and feedback. Then on VCR the mic barely picks up any sound and then on the Card PB function, I get ok volume but the sound quality just isnt that good and there's a ton of white noise when I'm not talking. How would someone suggest I go about getting just audio without simply recording myself talking on DV tape. I have a ton of voiceovers to do and simply running the audio on DV taped while filming black or whatever it's pointed at is not practical. Thanks!
Reed Poole April 23rd, 2003 06:55 PM
I'm not sure if this will work, but try just unplugging the speakers from your computer while you're recording. I think the feedback and distortion comes from the camcorder mic picking up the its own recording from the speakers.
Reed
Bryan Roberts April 23rd, 2003 07:24 PM
Ah, I found out that I had to change a setting in the camera itself under the AV/OUT menu. HOWEVER, now there is an annoying hum and I can only get mono sound even though I have the recorder in Sound Forge set to Stereo. My guess is that the hum is from my plug somehow...
Yow Cheong Hoe April 24th, 2003 04:10 AM
The 852 mic is pretty good, but a lot of digital wizardry goes on in the camera before the sound is recorded onto tape.
I'll suggest that you run the included AV cable and plug in the red and white into a hi amp, then out the amp into your computer's soundcard. This will be done on tape record mode. The logic is that the amp will cut some of the noise. You should then capture teh sound input on your PC.
The hum that you hear is due to the equipment not grounded (earthed). The power leak and causes a hum. I have this problem when I hook the cam life onto my church soundboard. So far, no way out. But the hifi amp that I have works, somehow.
And Reed is right, you should not play out sound fromt he speakers on your PC or the cam itself to prevent feedback.
Hope that this works.
