GS400 16:9 uprez
How good is the 16 :9 in camera uprez with GS400. Comparable to DVX100A when set in progressive?(see A Wilt test) Is progressive in GS400 in "thin" mode by default?
Andre,
Not sure what you mean by in-camera uprez 16:9... the GS400 uses a 16:9 footprint on the CCD in Wide mode, with a wider angle of view than in 4:3 mode. It's actually downrezing from 1152x646 to 720x480 in Wide mode, as illusrated on this page. GS400 doesn't do progressive, and DVX100A doesn't do real 16:9, so it's tough to compare. Josh |
Andre: The GS-400 has 1/4.7" hi res CCD's which would appear to be the same as the Sony PDX-10 (or at least the specs match). So it's actually doing real 16:9 and is in fact "downrezzing" the image to 720x480 (or 720x576 PAL).
Thanks Joshua and Boyd. I tought it was a letterbox uprezzer. The question on progressive scan relates to what I read in the Users Manual PAL(bottom of pg 26): "Wide/pro-cinema... In addition to the effects on Wide Function,
images are recorded at a rate of 25 frames a second with a strobe-like effect." Maybe just for PAL version? |
Hope this helps.
MX5000 Frame Grabs (**In 16:9 mode: MX5000 < GS250/400) http://www.dvuser.co.kr/zboard/data/gallery/glow2.jpg http://www.dvuser.co.kr/zboard/data/gallery/glow3.jpg |
Some people like this mode, others don't. |
Thanks Benjamin, but why do you think that frame mode is a deinteraced version and not a native progressive picture ? See http://www.adamwilt.com/DV-FAQ-etc.html#filmlook about frame mode.
Maybe somewhat more background info why I started this thread. I have a Sony VX2K. A good camera especially in low light conditions, but it has a poor 16:9 uprez image (vertical resolution and artifacts)..I want 16:9 on my widescreen LCD displays (37"Sharp and 40"Barco).. instead of side panneled 4:3 pictures. In addition to that I luke a smaller DV camcorder for traveling.
Andre, have you ever looked at the PDX-10? If you like the VX-2000 then it would see very familiar. It also has the advantage of DVCAM recording, hi res BW viewfinder, XLR inputs and a short shotgun mike. The XLR box and mike are removable for those times when you want something small, and the camera also has builtin stereo mikes. It will give you very nice 16:9 but no frame mode.
It has perhaps been discontinued however, see the discussion in the PDX-10 forum. I suspect you can still find them though, probably at a good price too. Of course the new Sony HDR-HC1 and HVR-A1 would also give you nice widescreen in a very small package, plus HDV. Maybe more than you want to spend though. |
Yes Boyd PDX10 looks fine too. I will look at it in more detail (and see if still available in Europe). About the Sony HC1 I still have questions on how it handles low-light sitiuations (window and level mapping trade-offs)) and fast moving objects (rolling shutter). Also my NLE is not MPEG2 compatible,,,
If you aren't ready for HDV then the HC1 allows you to shoot in regular DV mode (AFAIK), but you still have the advantage of the hi-res 16:9 native CCD's. When used this way you avoid the MPEG issues with movement.
Boyd, I mean the CMOS related motion problems with fast motion caused by the rolling shutter.
I have a PAL version of the GS400 and now always use the 16:9 widescreen mode. This delivers good results for me. I understand this mode uses 50 frames per second interlaced in PAL format.
I have not used the 16:9 "pro-cinema" frame mode. This uses 25 frames per second full frame mode. |
Thanks for correcting me David. Indeed , the "wide" mode produces standard interlace anamorphic pics (you mean 50 interlaced fields/sec.I suppose). I am not a specific progressive scan enthousiast, but depending on the camera's vertical filtering (thin/thick)and the performance of the deinterlacer/rescaler in flatscreen LCD displays, vertical resolution can be higher for native progressive images.
This subject came up on one of the DVdoctor forums recently, to be found here:
http://dvdf.hexus.net/showthread.php...t=GS400+16%3A9 It may be of interest. The expert here is Alan Roberts. |
