DVSPOT review GS400 vs GS200
In the DVSPOT review, the reviewer concluded if you did not need all the manual control and lower resolution stills, that the GS200 would be more suitable a camera. Does anyone have thoughts on this statement? I was set on getting a GS400 after reading the camcorderinfo review, but now i am thinking twice. Please try to convince me otherwise.
Mark |
There are a lot more differences between the two than just manual control the resolution of the stills.
Optical Image Stabilization Quality 16:9 mode Frame mode Pro Cinema mode (cine-like gamma, frame, 16:9, 6dB+) Manual Color Manual Sharpness Manual Exposure Manual Contrast Multi-Function Ring (zoom, focus, shutter, iris) Zebra stripes and color bars Manual audio Those are the differences that come to mind but I'm sure there are more (like the GS400 having a longer zoom and bigger CCDs). You'll also notice the better low light performance of the GS400 compared to the GS200 in the Camcorderinfo.com review. |
I can understand this conclusion if you are strictly a 4:3 shooter, like small cams, and don't have much use for manual control. Picture quality wise, the GS200 and GS400 will be similar in 4:3. Optical image stabilization on the GS400 will give it an edge in lower light.
The GS400 has larger CCDs and lot more video effective eyes (pixels) to capture information.
<<<-- Originally posted by Guy Bruner : I can understand this conclusion if you are strictly a 4:3 shooter, like small cams, and don't have much use for manual control. Picture quality wise, the GS200 and GS400 will be similar in 4:3. Optical image stabilization on the GS400 will give it an edge in lower light. -->>>
I was thinking about the same thing. Not sure if I want to carry a "larger" camera arround. If the video quality is almost the same as the gs200, I will ebay the gs400.. -Thomas |
>>>The GS400 has larger CCDs and lot more video effective eyes (pixels) to capture information.<<<
>>>If the video quality is almost the same as the gs200, I will ebay the gs400.<<< Makes sense. :-)) |
<<<-- Originally posted by Thomas Smith :
If the video quality is almost the same as the gs200, I will ebay the gs400.. Based on all the time I spent trying to like the GS200 and a tape full of sample footages of the GS400 taken in various stores, only the color saturation is similar...in terms of clarity and details...not even close...not even in the same class as the cheaper 1-CCD Sony HC40 and Canon Elura70 on those particular aspects...and there's no way to manually adjust sharpness. But yeah, the size of the GS400 may be a concern to some. Assuming the overseas models are exactly the same as the Jap one, here are a few more differences. 700MP effective video pixels against 440MP Low dispersion Leica Dicomar glass Improved Crystal Engine Bigger and higher resolution LCD More powerful built-in flash Bass enhancer Smooth color night mode More manual shutter speed settings under card mode High speed USB2.0 But if you need MPEG4, the GS200 has it. In terms of low-light, I think they are about the same. |
Here is Camcorderinfo's review of the GS400. Take a look at the 15lux frames. Click here |
