-   Panasonic DV / MX / GS series Assistant (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/)
-   -   Anyone know which camera would match the EZ30U? (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/27766-anyone-know-camera-would-match-ez30u.html)
Paul Jason June 18th, 2004 01:32 PM
What camera footage will match the EZ30U better? A Panasonic EZ1 or a GS200?
Frank Granovski June 18th, 2004 03:30 PM
A PV-DV950, which is the consumer version of the AG-EZ30U. After that, probably a Canon GL1. The GS120 and older GS70 might come close in terms of resolution but not in noise.
Paul Jason June 18th, 2004 03:50 PM
Thanks Frank for the information. The rental house here has two Panasonic cameras, the EZ1 and the GS200. Of those two, will either of them work? or should I try and find another rental place and go for the two camera's you mentioned.
Frank Granovski June 18th, 2004 04:23 PM
For the best match, I'd go for another EZ30 or a PV-DV950. Why take a chance? I often see used DV950's going pretty cheap you know where. (Just disengage the built-in image stabilizer, on both cams.) :-))
Paul Jason June 18th, 2004 04:46 PM
I thought that might be the case but was hoping one of the other cameras might work. Thanks again Frank.
Frank Granovski June 19th, 2004 12:10 AM
I remembered earlier today that the AG-DVC10 and AG-DVC15 share the same CCDs, engine and lens than the AG-EX30U and the PV-DV950. I wanted to post it but I had to go out shopping with my wife.
Peter Jefferson June 19th, 2004 05:38 AM
theres one on sale at ebay australia :)
cant find it now.... :( but its there
Paul Jason June 19th, 2004 08:11 AM
Thanks for all the replies. If anyone knows of a place in the Atlanta area that will rent one of the above cameras, let me know.
