-   Panasonic DV / MX / GS series Assistant (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/)
-   -   question on dv852 (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/21897-question-dv852.html)
Carol Bartholomew February 24th, 2004 07:19 PM
question on dv852
hello all
i recently purchased a dv852 from b&h
overall i like the camera but have a question
about the jack a/v input on the camera
it seems that the plugs don't go all the way in
i've tried headphones and the supplied a/v cable
does anyone know if the plugs are supposed to
snap/be flush with the camera or is ok to have a little bit sticking out
thanks for any help
oh
i found the perfect padded sleeve for the camera
it's a lowepro #2 lens case
http://www.lowepro.com/pages/series/...es/lencas2.htm
the dv852 fits it like a glove
Frank Granovski February 24th, 2004 08:06 PM
As far as I know, the plugs should push in all the way. Maybe the sockets are tight.
Carol Bartholomew February 24th, 2004 08:19 PM
thanks for the reply
yeah
i tried pushing the plugs all the way in
but they just seem to stop
didn't want to force anything
well
maybe someone with one can answer
Aykut Ozen February 24th, 2004 09:44 PM
i own a 852, yes the a/v port is a little tight...push it harder, it works:)
Yow Cheong Hoe February 25th, 2004 10:20 AM
Just check on the output. If you get video and true stereo left adn right, then you are pluging it right.
