-   Panasonic AVCCAM Camcorders (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/)
-   -   Not working (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/491241-not-working.html)
Lee Turner February 4th, 2011 10:55 AM
Not working
Hi, Can i be this thick ? I have my 101 and brought a ef to mirco 4/3 adapter. Turned on the camera, witha lens fitted, all i have is black, adjusted the iso, shutter rate etc and nothing. am i doing something wrong ?
Joachim Hoge February 4th, 2011 11:40 AM
Did you take off the lens cap?
On a serious note..
What lens do you have?
I noticed some lenses donīt speak well with the camera. Like the older 4/3 9-18mm Olympus you canīt change focus or iris. You do get a picture though
Lee Turner February 4th, 2011 11:51 AM
I checked and checked again, im using a canon ef lens. It driving me nuts ,
Stephen Mick February 4th, 2011 11:53 AM
Under the OTHER FUNCTIONS menu you should see an item that says LENS CHECK. Set this to OFF and see if that helps.
Lee Turner February 4th, 2011 11:57 AM
still not working , all the displays are there, but just black, just link i have the lens cap on ,
Lee Turner February 4th, 2011 12:00 PM
I have the same adapter as this , and make of lens - http://www.dvinfo.net/forum/panasoni...nanoflash.html
Stephen Mick February 4th, 2011 12:28 PM
I don't have that particular adapter/lens combo, so I may not be of much help, but…
The aperture on your EOS lens may be closed.
I believe with those mechanical adapters, you have to set the aperture on your Canon EOS lens to "wide open" on a Canon DSLR. So if you've got an f2.8 lens, set it to f2.8 on your Canon DSLR, and remove the lens (while the camera is still on, I think).
Now your aperture should be open, and you should (maybe, I hope) be able to mount the lens to your AF-100/adapter and see something.
Maybe.
Olof Ekbergh February 4th, 2011 04:37 PM
Make double sure LENS CHECK is OFF. In other functions menu. This is usually the cause.
