-   Panasonic AVCCAM Camcorders (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/)
-   -   HMC40+1/8" mic adapter (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/487405-hmc40-1-8-mic-adapter.html)
Dina Fiasconaro November 12th, 2010 12:01 PM
hello,
I'm using an HMC40 with a shotgun mic attached via an 1/8" adapter. It seems that this setup automatically disables the 2nd channel of audio and is only seeing/recording the shotgun on Ch. 1, but is not seeing/recording the onboard mic on Ch. 2 (which is what I'd like it to do).
I must have something set incorrectly, but cannot figure out from troubleshooting or the manual what that might be.
Thanks for your help!
Mike Beckett November 12th, 2010 12:16 PM
Dina,
The shotgun mic is mono, and the XLR- 1/8" adapter is probably mono only as well, which is why you only get one channel. I'm sure it's been covered on here before if you search. I don't think the HMC4x has a menu setting to duplicate the audio channel.
You would need a lead that provides audio to both stereo channels via the 1/8" jack. I'm not sure what it's called, I use the XLR unit on my HMC41, which also allows me to record the shotgun mic onto two channels at two different levels, so I can cope better with unexpected loud sounds, for example.
Maybe something like this:
http://www.bhphotovideo.com/c/product/158477-REG/Hosa_Technology_XVM_105F_Stereo_Mini_Angled_Male.html
"This Hosa Stereo Mini Angled Male to 3-Pin XLR Female Cable is specifically wired to convert a mono microphone or line level signal to both left/right contacts of a mini 3.5mm (1/8") stereo plug. This allows microphones and mono output devices to be connected to the stereo inputs of camcorders without phase cancellation and single channel operation."
Dina Fiasconaro November 12th, 2010 12:28 PM
Thank you, Mike.
I do understand that both the shotgun and jack are mono. I was more so wondering if there was a way to set the camera to record the shotgun to one channel and the onboard mic to the second channel, like you can with other cameras like the HVX200.
Mike Beckett November 12th, 2010 02:36 PM
Sorry Dina, I always try to cover the bleedin' obvious!
I think the channel replication is only available for XLR - I think the HVX is all XLR? No software option for our HMC-tinycamera people that I know of.
Chris Harding November 12th, 2010 08:50 PM
Hi Dina
Inside the 1/8" socket in the camera is a connector that disconnects the internal mic completely when you push a jack plug into the socket!! The only way to bypass it would be to change the socket.
However what you can do is remove the 1/8" mono plug from the mic cable and replace it with a stereo one and then bridge the two live terminals so you mic output is fed into both camera channels.
The other option is to use a stereo to mono splitter which is essentially a 1/8" stereo jack plug on one end and two mono sockets on the other. That way you can feed your shotgun into one mono channel and a second mic of your choice into the other to "use" the second channel.
If you had something like a Rode Stereo mic then it would feed both channels for you...probably the nicest option??? Azden also make a stereo shotgun mic that will also feed both channels.
Chris
Sherri Nestico November 18th, 2010 05:21 PM
My Rode Videomic records to both channels
...on my HMC-40 using the 1/8 jack. I didn't have to go into the audio menu to set anything, it worked that way right out of the box.
