-   Panasonic AVCCAM Camcorders (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/)
-   -   HMC150 Batterys and chargers (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/478743-hmc150-batterys-chargers.html)
Stu Ross May 15th, 2010 03:01 AM
Attention HMC 150 Owners.
Can you please tell me what size battery came with your HMC150. I have looking at a couple of places some say its 2460mah and others say 5400mah.
Would this just be a miss print or is it possible that the camera comes stock from different places with different sized batterys.
Also does the camera come stock with a stand alone charger (ie. not needing to be connected to the camera to charge)?
If no can you suggest a good aftermarket stan alone battery charger and where to get them from.
thank you
Chris Harding May 15th, 2010 07:24 AM
Hi Stu
Depends on the package!! My mate Shaun got the big battery from GMP when he bought his!!
You always get a standalone charger but BEWARE!! You can ONLY use the genuine HMC batteries or IDX from the USA...Generics do NOT work!!!! I would just stick to the Panny charger that comes with the camera BTW: If you import the IDX battery it cannot display the time left on your EVF..but works in the camera!! The 5800mah battery costs around $200+ from GMP so factor that into your costs if you find a sweeter deal!!! You might just get the smaller battery and a $200 discount!!!
Chris
