-   Panasonic AVCCAM Camcorders (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/)
-   -   HMC150 car battery charger (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/449215-hmc150-car-battery-charger.html)
Greg Harris September 28th, 2009 08:58 AM
Does anyone know where I can get a car charger so I can charge my hmc150 batteries? I would think this would be cheaper vs. buying new batteries that cost $200.
Greg Harris September 28th, 2009 09:03 AM
never mind, I found one here.
Panasonic | VW-AD20PPK AC Adapter & Charger | VW-AD20PPK
Larry Hill September 28th, 2009 11:27 PM
Not trying to be smart alec, but this doesn't look to me like what you described - it requires a 110-240v AC input.
With only a bit of searching I haven't been able to find a Panasonic auto adapter.
Barry Green September 29th, 2009 07:28 AM
I don't know of one, but you could always just get a little cigarette-lighter inverter for the car, and plug your regular charger into that...
Greg Harris September 29th, 2009 08:32 AM
oh yeah like this one!!
Enercell™ 150W Power Inverter - RadioShack.com
YES!!!!
Thanks Barry!!
Denny Lajeunesse October 6th, 2009 02:16 AM
I did not find a car charger but I did find a regulated stepdown converter (12v to 7.2v) off ebay. Coming from Hong Kong. Should be here any day now. Cost me $30.
The one I ordered is variable but you can lock in the voltage. Anyhow. You can use a 12v battery or car end, wired to the converter and use a female end that matches your power supply cable (the part that plugs into your charger to power your camera off mains).
I'm using the above to power the cam off 10ah 12v batteries. I'm building a steady cam (last one I built years ago was stolen) and will be using the batteries on the steady cam. Also great on a belt.
I suggest the more efficient regulated and protected voltage converters but ou can get away with a simple fixed voltage regulator if you are handy with a soldering iron. you can find the schematic online. A child could make one really. :) They are also on ebay some times.
EDIT: Sorry, just noticed you wanted it for charging panny batts. So far an inverter is the only way to go. I should read the full post before replying. lol.
