-   Panasonic AVCCAM Camcorders (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/)
-   -   Trouble capturing HMC150 footage via component (https://www.dvinfo.net/forum/panasonic-avccam-camcorders/236290-trouble-capturing-hmc150-footage-via-component.html)
Jeff Harper May 28th, 2009 03:49 PM
I'm using a canopus box to capture hd footage from hmc150. I've got component out to canopus, etc When attempting to capture footage the image that is captured is the thumbnail images on the LCD screen of the camera, its not capturing the footage...I feel kind of lost here, any suggestions?
David Jonas May 28th, 2009 04:01 PM
Again I don't have the HMC, however you probably would have to change the output settings in the playback menu for the HMC to SD.
David Jonas May 28th, 2009 04:09 PM
From the manual, you need to switch to downconvert mode 480i.
Jeff Harper May 28th, 2009 04:26 PM
Thanks David. Same issue, but at least I'm on the right setting, thanks to you. Vegas only sees whatever is on the LCD screen....
