-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Premiere and 16:9 (https://www.dvinfo.net/forum/open-dv-discussion/965-premiere-16-9-a.html)
Peter Koller February 15th, 2002 01:22 PM
Premiere and 16:9
When I am shooting I have my notebook firewired to the XL1 and use it as a controlmonitor. I also record each take on the harddisk for replays, which I find very convenient.
I am capturing the footage with Premiere 6.0 and the question is:
During the capture the Movie-Capture-Window shows what´s coming from the camera, BUT when shooting in 16:9 mode it shows the vertically streched 4:3 image, just like the viewfinder of the XL1 does.
After the capture, when the clip is moved to the Monitor-Window, the footage is displayed in the correct 16:9 ratio and everythig is fine.
At the moment I am resizing the Movie-Capture-Window during the capture and more or less squeeze the image to its right proportions, so I can see the live footage correctly. This seems like a crude solution to me. Is there any other way to get the Capture-Window to the correct ratio?
Cheers, Peter
Ed Smith February 15th, 2002 02:11 PM
Are you using the 16:9 setting in premiere (bit right at the start when the program starts to boot up)?
Seems a bit of dumb question to ask you, but I thought I would.
Hope this helps,
Ed Smith
Peter Koller February 15th, 2002 05:59 PM
thanks for the hint Ed,
the problem seems to be the DV300 driver, it occurs only if I use my customized settings of the DV300 on my desktop pc.
But it seems to work fine when I switch to Premiere´s standard PAL 16:9 setting and the IEE1394 device driver. This Pinnacle thing is a mystery to me...
Thanks for the input,
Peter
