workflow problems with scenalyzer, compression, letterboxing and some other things
Here's our problem:
We're shooting with a lens adapter in 16:9 on the pdx10p. We're using Scenalyzer to capture. Our movie will be anamorphically letterboxed and because of the lens adapter the image also has to be rotated, these things have to happen before editing (which happens in Vegas because Premiere does not support the not-so recent CPU in the PC that's used for editing). To do this, we just throw all the clips into After Effects, apply the rotate and letterboxing to all compositions and render it out to Quicktime Animation to keep it lossless (very important). Problem: this whole process (from capture to completed rotate/letterboxing render) takes about 4 hours and 90gb. I've checked out other lossless formats that take up less space but they seem very heavy and our editor has to be able to work smoothly (and doesn't have a super-powerful workstation). Ideas? Thx. :) |
You don't say what the 'lens adapter' is you're using on the PDX10. You mean a 1.33:1 anamorphic? If so, why not use the in-built 16:9 capability? I'm at a bit of a loss to understand the 'ananamorphically compressed and rotate' terminology. What is it that you're trying to achieve on the final viewing screen?
tom. |
Ah-ha. Much clearer now. If ''it works better for the look of our movie'' then it's not bad practice in my book, and the PDX10's resolution is so good (as long as you keep the aperture at f/4) that it can take a hit without flinching.
tom. |
