-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   48mhz 24bit audio into Premiere 6.5? (https://www.dvinfo.net/forum/open-dv-discussion/86010-48mhz-24bit-audio-into-premiere-6-5-a.html)
Han Kim February 8th, 2007 09:27 PM
I recorded voice in 48mhz 24bit. Then, I realized Premiere 6.5 only uses up to 16 bit. Will this cause problems? I can get the 16bit, if I need to...
Also, I have some 44.1 mhz files. Can I convert them in Premiere 6.5 or do I need another program?
Thanks tons!
Graham Risdon February 9th, 2007 08:32 AM
If I get other file formats in for editing, I normally convert them in Adobe Audition to 48k 16 bit and then bring them into Prem like that, cleaning them uop if necessary befor eimport (noise reduction, a bit of compression etc,)
I guess you could try and set up a temporary project with a different rate and render the audio out to the right rate...
