-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Canon ZR70 (https://www.dvinfo.net/forum/open-dv-discussion/8066-canon-zr70.html)
Ron Johnson March 26th, 2003 06:17 PM
Canon ZR70
Hi All - I am thinking of picking up a smaller mini-DV cam for better portability and odd jobs. Since I own a GL1 and will soon upgrade to a GL2, I guess I'm a Canon fan - the extra long optical zoom is too thrilling to let go of easily. Anyway, if anyone has experience with the ZR-70, I would appreciate feedback.
Two particular areas of interest:
a) Will the camera pass a video signal to the analog outs if there is no tape in the drive? (And can the camera be kept ON continuously?)
b) Does the ZR-70 have full pass-thru like the GL1? For example, w/ 1394 IN, the GL1 outputs composite and Y/C video simultaneously, and for any analog IN, the GL1 passes a digital stream to the 1394 port.
Also, if anyone knows of a similarly equipped and priced unit, I would love to know about it!
Sincerely,
Ron J.
Chris Hurd March 26th, 2003 07:38 PM
The answers to your questions are a.) yes and yes; b.) yes. The less expensive Canon ZR65MC and ZR60 do the same as well. Hope this helps.
Stewart S March 27th, 2003 02:30 AM
I just picked up the ZR-60 today and haven't spent much time with it. I thought I had researched it very well, but it doesn't have true exposure control as I was led to believe, just shutter and exposure compensation for the AE.
Ron Johnson March 27th, 2003 06:49 PM
Thanks for the replies, esp. Chris - your answers were perfect.
Ron J.
Jed Williamson March 27th, 2003 09:04 PM
I'm not sure if this would be usefull or not.
but they are selling a zr-60e pal model here in the US.
That is only 1 frame away from Sundance!
Trey Perrone March 29th, 2003 11:13 AM
Ron, i have no prob passing video thru the cam out to analog, but i have not gotten my GL1 to pass analog in thru firewire. If i have analog i usually record in the cam and then capture off 1394. Any tips on passing straight thru?
Ron Johnson March 29th, 2003 01:03 PM
Trey - Y
You are correct, I had gotten my modes confused. I can only get firewire output when the camera is in Play or Camera mode.
Sorry for any confusion.
Ron J.
