-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   I got the "pookies" (https://www.dvinfo.net/forum/open-dv-discussion/7781-i-got-pookies.html)
Bruce Fenton March 16th, 2003 06:45 PM
I got the "pookies"
Have a 3rd generation VHS tape, made in the 1980's. It contains one-of-a-kind Smithsonian Grade information regarding long gone Japanese master craftsmen.
Tape degradation has caused the horizontal snow storm which I call "Pookies".
Aside from going into each frame in Photoshop, does anyone have any quick tricks to clean this up?
The best thing I found so far is to duplicate the clips on A snd B, blur B until the snow is gone and then selectively key the images, scene by scene.
This works O.K. but there must be something better,
Any ideas?
-b
Jeff Donald March 16th, 2003 07:19 PM
There is no quick fix or everyone would be using it. The best way, is as you describe, doing one frame at a time. If the footage is as rare and unique as you describe then you have to decide if it's really worth the effort.
Chris Hurd March 16th, 2003 08:50 PM
You might try getting ahold of a full-frame time base corrector (TBC). Sometimes a TBC can really clean up the pookies. I have a JVC S-VHS deck, the HR-S9800U, with a full-frame TBC inside and it does a decent job. Since you're in Boston, you should be able to buy or rent a TBC. Good luck,
