-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Please help (https://www.dvinfo.net/forum/open-dv-discussion/66967-please-help.html)
Rich Sheikh May 9th, 2006 07:50 AM
Please help
Would someone please explain to me why I'm getting dark spots in the corners of my video footage. I'm using a one chip Sony camera and the only thing on the lens is a UV filter. I do zoom in sometimes. Here is a short movie and you can see what I mean about the dark spots in the corners.
http://homepage.mac.com/richsheikh/weddingday/
Rich
Andrew Khalil May 9th, 2006 12:18 PM
that looks like vignetting and can easily be caused by the UV filter - try removing it and see if the problem goes away.
Some lower quality lenses will also do this if used wide open at full wide angle - stopping down the aperture should solve it in that case, but I think your problem is more likely the UV filter.
