-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Black side lines? (https://www.dvinfo.net/forum/open-dv-discussion/64946-black-side-lines.html)
Laurence Currie-Clark April 12th, 2006 06:45 PM
Black side lines?
I'm shooting with a VX1000. All my footage (when viewed on computer) has thin black lines on both sides. First of all, why is this?
Secondly, when exporting to web, can't I save alot of file size by cropping off these bars?
Thirdly, does this happen with all cameras, or only the VX1000 model?
An example :
http://wiki.theskatepress.com/media/Test.mov (600KB)
Thanks in advance,
Laurence
Doug Boze April 12th, 2006 08:01 PM
This is probably normal. What you see on the computer is the full-frame, or 100%. The action-safe area of an image is approximately 80% of that, and is what you can reliably see on a television. You won't save much by cropping. Since the black lines never change, the compression will be optimum.
