-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   what lights do i need for lighting a green screen (https://www.dvinfo.net/forum/open-dv-discussion/63882-what-lights-do-i-need-lighting-green-screen.html)
Jim Rog March 28th, 2006 06:28 PM
Hello
Can anyone tell me what kind of lights are best for lighting a green screen? can you recommend any other keyer beside the vegas one
i want an add on/plug-in that work's better with green then the standard one in vegas
Craig Chartier March 28th, 2006 07:42 PM
whichever ones work. Actually your looking for a flat line as seen on a waveform scope from side to side . It should only be a stop or two above subject. and you need to have a certain amount of distance between the screen and the subject. Too much spill will result in poor key. usually a good rim backlight on subject will help with the spill. Tungsten lights seem to be used quite alot for this type of lighting. Good luck
Don Donatello March 28th, 2006 10:40 PM
BEST - use the "kino flo" green screen lights = $$$$
keyer software - ultra 2 , primatte 3 , keylight ...
