-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   16mm film scanner (https://www.dvinfo.net/forum/open-dv-discussion/54593-16mm-film-scanner.html)
Gabor Lacza November 17th, 2005 10:48 PM
16mm film scanner
Guys,
anybody has any idea if it would be possible to scan 100ft 16mm movie film on a Scanner frame by frame?? Nikon has a scanner which accepts 16mm film....
Gabor
Dylan Tucker November 17th, 2005 11:22 PM
I dont see why you wouldnt be able to...It would just take a long time
Don Donatello November 17th, 2005 11:43 PM
the nikon 16mm adaptor was meant just to capture single frames NOT to be used to capture sequences as there is no registration pin ... you might look at the JK optical printer with a digital still camera in stead of a film camera ..
the JK has registration pins to keep every frame aligned with each other .. you can put canon/nikon/fuji still camera to record images at whatever resolution your camera will do .. the JK will operate the still camera .. on some camera's it will transfer images automatic over USB to computer .. approx $5-7K without camera ... used 1500-2500 for older JK printer ..500 for control device .. $$ still camera ?
you might try using the nikon and and then use a program like combustion that can pin the 4 corners of the frame using stabilization = might just work ? you would need to see all 4 corners of the frame ...
Don Donatello November 20th, 2005 11:10 PM
came across this on using flat bed -slide scanners ...
http://truetex.com/telecine.htm
Richard Alvarez November 21st, 2005 08:37 AM
Guys,
No sense re-inventing the wheel.
http://www.moviestuff.tv/
They make transfer/capture for 16mm film. Unlike standard telecine, this captures each frame directly to your computer.
