Does codec or color space matters in live green screen?
If I'm doing a live streaming show with greenscreen using Tricaster, does the codec matters (XAVC-I or XAVC-L) or 422/420 or the camera matters when I'm not even recording?
Re: Does codec or color space matters in live green screen?
No, the "live" HDMI or SDI output will be 4:2:2 without compression regardless of internal record codec setting.
Thanks Jeff |
Hi thanks for your answer. Most camera will output 422 thru HDMI and SDI?
Correct, 4:2:2 is the standard over digital outputs.
I'm looking at getting Sony HXR-NX5R for live green screen works. Checked the manual but there is no mention of 8 or 10 bits, 422 or 420 output through SDI. It only mention "BNC type (x1), SD/HD/3G(Level-B) selectable SMTPE 259M/292M/424M/425M standards". Is it still able to output 422?
