-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Free DVD burning software (https://www.dvinfo.net/forum/open-dv-discussion/535079-free-dvd-burning-software.html)
Harry Lender December 12th, 2017 11:28 AM
Question;
I have a Video DVD that I created in Adobe Encore several years ago and a no longer have the Project files. I have moved to Win10. The ISO file that I had created but now it is in a 7z Folder which contains 2 folders with
an Audio_TS and Video_TS file folders. The iso file that I use to use to burn DVDs is not there. Can I use a free burning software to burn a DVD or how can I get the Audio_TS and Video_TS files converted to a.ISO file so that I can start burning DVDs again. I have searched the forum but with no luck.
Thanks in advance.
Harry
Battle Vaughan December 12th, 2017 12:35 PM
Re: Free DVD burning software
I found this on a Google search, might be worth a look: https://www.wondershare.com/dvd-burn...ts-to-iso.html
Dave Farrants December 12th, 2017 12:38 PM
https://www.dvdstyler.org/en/
Ron Evans December 12th, 2017 01:30 PM
The Official ImgBurn Website
Jeff Pulera December 12th, 2017 02:03 PM
Hi Harry,
If you don't find a solution to getting the VIDEO_TS files back into a DVD format, maybe try this - Premiere can Import the .vob files you have. Drop them into a timeline, then export as MPEG-2 DVD. Yes, you would be recompressing the content again, but just in case you have no other option this ought to work. Assuming you still have access to Premiere and Encore
Just found this software that claims to do exactly what you need - https://www.aimersoft.com/tutorial/video-ts-to-iso.html
Ron Evans December 12th, 2017 05:37 PM
If he has the audio and video ts files he has to do nothing but burn to a disc. He does not need an iso file. Those are the files on a DVD if you look. An iso file is an image of the disc which contains these files in disc format. Imgburn can use these files and burn a disc. It can take these files and create an iso file if that is desired. It can read a DVD and create an iso file etc. It is a very good burner too. The one advantage Nero burning ROM has is the ability to burn from multiple drives at the same time. I have both.
Tony McGuire December 13th, 2017 03:27 AM
I use Magic ISO I know its not free but for about 40 euros I paid for its well worth it as I use it all the time to burn ISO files to disk be it CDs or DVDs the ones who make Magic ISO also make another peice of software called Magic Disk which allows you to mount ISO files as a DVD or a CD which can be very handy for checking disk images as well. Magic Disk is free
Jeff Pulera December 14th, 2017 03:06 PM
Good point, this WILL work with software that supports it, like ImgBurn. Just to clarify though, if one were to simply "write" the VIDEO_TS folder to a disc using Windows to burn data (drag to disc), that would NOT make a DVD playable in a set-top player since the DVD is not properly formatted as VIDEO DVD, but rather is simply a DATA disc with a VIDEO_TS folder on it, big difference.
Ron Evans December 14th, 2017 04:21 PM
Absolutely correct. Needs to be formatted like a DVD disc not a data disc. ImgBurn will do that as well as make an iso file for you to keep for the future. Its free too.
Christopher Young December 15th, 2017 03:58 AM
Originally Posted by Ron Evans (Post 1939437)
+1 on ImgBurn. Great bit of free software.
Chris Young
Derek Heeps December 20th, 2017 02:45 PM
I generally use Toast , but don’t know if it exists for Windows ?
Harry Lender December 29th, 2017 10:03 AM
Ron
Thanks for that. I'm looking into it. So many great suggestions here.
Harry
Harry Lender December 29th, 2017 10:07 AM
Ron:
Again thanks for your input. I finally did use Imageburn. Did great. Thanks again.
Harry
