-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Sony PJ710 Projector (https://www.dvinfo.net/forum/open-dv-discussion/514921-sony-pj710-projector.html)
Darryl Jensen March 9th, 2013 09:43 PM
I need to do a presentation next week. I copied my presentation onto the memory of my PJ710 thinking it would find it and play. I copied a 1.6 GB MOV file. But the Sony doesn't recognize the file... It just says there are no images in memory...
Now, my presentation is approaching and I'm not able to use my projector. Is there a way to make this work. Am I missing something?
I'd appreciate any and all suggestions.
Thanks very much
Warren Kawamoto March 10th, 2013 12:07 AM
Re: Sony PJ710 Projector
I'm not familiar with the PJ710 but after looking at the specs, it appears that your camcorder/projector does not play .mov, only MPEG4 or MPEG2. Try converting your presentation to specs compatible to those below and you should be fine. What NLE are you using? What is your .mov resolution right now?
Video Format : HD:MPEG4-AVC/H.264 AVCHD™ format ver.2.0 compatible; STD: MPEG2-PS
Video Mode : HD PS: Approx. 28Mbps / FX: Approx. 24Mbps / FH: Approx. 17Mbps / HQ: Approx. 9Mbps / LP: Approx. 5Mbps; STD HQ: 9Mbps
Video Resolution : HD:1920x1080/60p(PS),24p(FX,FH),60i(FX,FH), 1440x1080/60i(HQ,LP); STD: 720x480/60i
Video Actual (Pixel) : Approx. 6140K pixels (16:9), Approx. 4600K pixels (4:3)
Video Signal : NTSC color, EIA standards
Ron Evans March 10th, 2013 09:28 AM
Your NLE needs to be able to format and send the output to the camera. I know Edius that I use will do this. I think Vegas will do this too.
Ron Evans
