Didn't get second audio channel in Scenalyzer?
Hi there
I just bought Scenalyzer and am using int to digitize my footage. I am wondering why it did not write the second audio channel to a wav file. I had it checked to YES and the video was to pull audio from the first channel. The footage definately has two channels to the video. Can anyone explain what happened? thanks |
i'm going off the cuff here, can't remember for sure, but don't you also have to tell scenealyzer that it's 32khz audio to enable the 4-channel capability? otherwise it'll think you are putting in the standard 48khz 2-channel dv audio, regardless of what you have checked.
shoot, been emailing Andreas the writer of the program.
Scenalyzer will write a second wav file if the sound is 32kHz only, if it's stereo 48 kHz,it doesn't so that. It takes each channel as right and left sides of a single stereo track, he says. But when I put my footage in Premiere 6, I get only channel 1, mono...... strange. |
| All times are GMT -6. The time now is 05:55 AM. |
