3-4 Person Wireless Intercom System
I have been doing market research on wireless intercom systems for camera operators and a technical director. A wired system is hard to set up and take down in the venues I often work (ice rinks). It seems like the inexpensive systems have serious drawbacks (i.e., Eartec is only duplex for 2 users and more becomes one-way comms) or very expensive with "pro" systems in the $3K-$5K range.
[Looking at other Eartec, the Eartec Simultalk 24G Three-Station is in my preferred price range. Is the audio quality good enough though?] Has anyone found a less expensive solution that is fairly sturdy and has acceptable specs? The environment is not particularly noisy. I like the Anchor Audio ProLink systems for example, but need something less than half the price. Would consider clean used gear or refurbished. Operating in the U.S. if frequencies are an issue. Thanks! |
Re: 3-4 Person Wireless Intercom System
I ordered the 4-station wireless Eartec from B&H. Cyber headphones and if it requires more isolation then I'll get the larger muff version as needed.
Hi Chip
What made you decide on the Eartec? I've been using an Eartec 900 for the last 7 years and have been looking at the Anchor prolink x4 as a replacement. Is their much of a difference between the Prolink and Eartec. Andy |
Andy, it was price. Once the business is benefiting from the better communication, I want to evaluate more expensive systems. Hopefully the cheaper Eartecs will continue to function until then.
| All times are GMT -6. The time now is 06:50 PM. |
