-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Best backing up solution on laptop (https://www.dvinfo.net/forum/open-dv-discussion/504215-best-backing-up-solution-laptop.html)
Nigel Davey January 9th, 2012 06:04 AM
I am a videographer for a UK charity and I need to purchase a new laptop able to excel in one specific area, 'backing up digital footage'.
Let me explain a little about my workflow and the challenges involved. I often travel to Asia for filming projects where I use a couple of solid state camcorders. I can shoot anything up to 60GB's of footage per day and at the end of each filming day I go back to the hotel and make x2 copies (in case of subsequent data lose) of all the footage from that day.
Currently I use two 2.5 inch external hard drives (7200rpm) daisy chained via USB 2.0 to my current laptop. I copy the footage straight from the Compact Flash memory cards inside the camera onto these drives, again via USB 2.0.
The process can easily take several hours, and that’s the problem I need to overcome. I assume the bottleneck is the USB 2.0 transfer rates since the memory cards inside the camera can transfer data at up to 60MB/s.
As mentioned I am now in a position to upgrade the laptop and accessories and I am looking for advice on the best way to reduce these back up times.
Currently I am considering purchasing another 13 inch laptop (travel requirements makes larger laptops impractical) with at least one USB 3.0, an e-sata port and a large internal hard drive, e.g. 1TB (7200rpm). Separately I thought I’d buy a USB 3.0 CF card reader and either a largish (750GB) USB 3.0 ext HDD or an e-sata equivalent. Whichever version I opt for, again they need to run at 7200rpm.
Thus on subsequent filming trips I could remove the CF memory cards from the camera and pop them into the USB 3.0 CF reader. I could then make one copy of that day’s footage directly onto the laptop’s internal drive and another on to the external USB 3.0 or e-sata HDD.
Right now I have a maximum budget of £750 to purchase all the necessary hardware.
So I have two specific questions:
1) Is the proposed solution the best one for overcoming the problem outlined, or can you suggest a better one?
2) Can anyone point me in the direction of a suitably priced (i.e. around £600) 13” laptop that has a USB 3.0/e-sata port and a large internal HDD running at 7200rpm?
Nigel.
Ervin Farkas January 10th, 2012 04:53 AM
Re: Best backing up solution on laptop
Something stinks!
Are you sure the USB connection is USB 2.0 on your current setup? 60GB should be transferred to a 7200 rpm hard drive in few tens of minutes, not hours.
Bill Koehler January 10th, 2012 06:54 AM
Originally Posted by Ervin Farkas (Post 1708535)
Something stinks!
Usb 2.0 handles about 2 GB per minute. But that bandwidth is getting shared both by reading the cards and writing to external storage. So moving 60 GB of media ends up being 30 minutes x 2 (reading and writing) x 2 (number of copies). So he's looking at a couple of hours, minimum. I can say the OP is on the right track in moving to USB 3.0. You should see your transfer times drop by over half. The bottleneck will move from being the connection method to the drive itself.
I use external hard drives for backing up my footage. I recently upgraded from USB2 to USB3 on my desktop. It has made a tremendous difference in the amount of time spent backing up and verifying footage.
