Economical Wireless A/V solution
I'm looking for an affordable wireless transmitter and reciever to run IR security cams back to my PC for capture (using a multi-input DVR card).
One problem I may have is that we're using 3 IR cams, so the transmitter/recievers will need to use different bandwidths so they don't bleed over onto one another. Also, the cams will be indoors, so I'm not sure how well transmitters/recievers work indoors. If anyone has suggestions or know of a cheap/good solution, please respond. :) Thanky! |
I haven't tried these myself, but at $49 it seems to be an affordable solution http://www.x10.com/products/vk54a_sp_lr_ps79.html
Also google "shotwatcher" and check out more robust systems at markertek.com |
