fader-nd anywhere ?
Hi, I'm urgently looking for a LCW 77mm Fader-ND, but it looks out of
stock everywhere. Does anyone know where it's in stock ? |
Yeah I couldn't find one either, not even ebay.
You want it for an HDSLR? Because I think the market has been stripped of them for that use. |
stack two polarizing filters - same effect,should do the trick
Yes, but I was also hoping to have the one you could rotate as I wanted to change while panning the camera from a dark scene towards the light without washout, I wonder if I could pull that off with a polarizer?
Crossed polarizers should do what you want - just won't have markings on them. I suspect that the variable ND filter has one fixed and one rotatable polarizer in it.
Hi,
Last week I called a company who said they had the Fader-ND 77mm. So I immediately bought it because I was in need for it and couldn't find it anywhere. Now I just received it, but it isn't the 77mm. It is the 82mm and they send a 77-82 adapter ring with it. What do you think of this ? Is this normal ? Will it give a difference in effect on my videos or is it just going to be the same ? |
82 to 77mm will work fine, that how I'm doing it.
I went the 2 polizer route (1 linear, one circular) for 77mm (as my biggest lens are 77mm) and I got step down rings to 72, 67, 62, 52 which are the diameters of my other lenses. |
| All times are GMT -6. The time now is 06:46 PM. |
